Vor 9 Stunden
Dear Colleagues,
since Googlemaps has changed their policy and F5FAV with NERIM.net is no longer available, I was trying to replace the html code for parts of the uiview web server, ao that open street maps could be used for big, medium and small map tiles would appear when you want to see the exact location of an received APRS station whilst using the uiview web server.
Has anybody done this already and could help out with the html codes further developed for the "special pages" - I have tried the help of Chatgpt, but this was a long-winding approach not really leading to the desired result: The station itself is not marked on the map tiles and these are not really fitting the frames - anyway you can see I was underway but this project nourished the idea whether somebody else has the same intention to make the Uiview web server useful again like it was before.
If you want to see the preliminary result I can give you the web adress.
Best regards from EA6ADB, Robert (DL1MBW)
dl1mbw@impleo.de
dl1mbw@impleo.de
