Folgende Warnungen sind aufgetreten:
Warning [2] Undefined variable $unapproved_shade - Line: 2 - File: inc/plugins/thankyoulike.php(1013) : eval()'d code PHP 8.3.14-nmm1 (Linux)
File Line Function
/inc/class_error.php 153 errorHandler->error
/inc/plugins/thankyoulike.php(1013) : eval()'d code 2 errorHandler->error_callback
/inc/plugins/thankyoulike.php 1013 eval
/inc/class_plugins.php 142 thankyoulike_postbit
/inc/functions_post.php 898 pluginSystem->run_hooks
/showthread.php 1121 build_postbit
Warning [2] Undefined array key "thankyoulike" - Line: 5 - File: inc/plugins/thankyoulike.php(1013) : eval()'d code PHP 8.3.14-nmm1 (Linux)
File Line Function
/inc/plugins/thankyoulike.php(1013) : eval()'d code 5 errorHandler->error_callback
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 54 - File: showthread.php(1650) : eval()'d code PHP 8.3.14-nmm1 (Linux)
File Line Function
/showthread.php(1650) : eval()'d code 54 errorHandler->error_callback
/showthread.php 1650 eval
LILYGO LORA32 Module with SX1268
Hi . I happen to have a LILYGO Lora32 Board with a SX1268 Lora Chip. The OE5BPA Software works only with SX1278. Has anybody experience with switching from SX1278 library to SX1268 or other  hints to solve this?
73, Klaus
Hallo Klaus,
welche Boardversion hast du vor dir? Die OE5BPA Firmware unterstützt derzeit noch nicht die neuste Boardversion. Möchtest du unbedingt diese Firmware nutzen? Ansonsten gibt es auch einen guten Fork von CD2RXU:
https://github.com/richonguzman/LoRa_APRS_Tracker
73 Martin
Moin Martin. Danke für den Hinweis. Der gute Ricon (CD2RXU) ist offenbar am Ball: Revision 2023.09.18! Im "Auslieferungszustand" klappt's nicht mit SX1268. Wenn ich die platform.ini ein bisschen verbiege*, dann funktioniert es. Jetzt muss ich mir die Zeit nehmen und meht platformio lernen. Wie z.B. die [env] Einträge verwendet werden. Auf jeden Fall muss man mit einem Upload warten, bis platformio die Liste der Menüpunkte in der linken Spalte beisammen hat.
73, Klaus
*Original:
[env:ttgo-t-beam-v1]
board = ttgo-t-beam
build_flags = -Werror -Wall -DTTGO_T_Beam_V1_0_SX1268
[env:ttgo-t-beam-v1_SX1268]
board = ttgo-t-beam
Mein (vorläufiger) Trick, 3. Zeile:
board = ttgo-t-beam
board = ttgo-t-beam
Prima. Das hört sich sehr gut an.
Ich nutze aktuell eine Firmware die von DL9SAU geforkt wurde. Finde allerdings den Ansatz von CD2RXU mit den Profilen sehr gut gelöst.
Wünsche dir aber weiterhin noch viel Erfolg.
73, Martin
ich versuche mich seit einer Woche mit dem
LoRa APRS Tracker von OE5BPA https://github.com/lora-aprs/LoRa_APRS_Tracker
und einem LiLYGo Modul T-Beam-V1.1 und komme nicht weiter.
Nachdem Start kommen folgende Displayanzeigen:
-OE5BPA...
-Info Lora Init done
-GPS Anzeige mit aktueller Zeit und Koordinaten
Sieht man in dem Display wenn das Ding auf Sendung geht?
Oder funktioniert es sogar schon?
VG
Ralf
Moin Ralf.
Verwendest du als IDE VisualStudioCode mit platformio?
Wenn ja, hast du in der data/tracker_config.json dein Rufzeichen eingetragen und anschschißend "Upload Filesystem Image" ausgeführt? Ohne diese Schritte geht nix. Eine Bake kannt du mit dem mittleren Knopf auslösen und ja, auf dem Display kommt dann die entsprechende Meldung. Das Netz der LoRA-Igates ist schon erstaunlich dicht. Wenn du also eine richtige 70cm-Antenne anschließt, dann solltest du auch auf aprs.fi auftauchen. Der mitgelieferte Stummel ist zu nix nutze, hat auch eine viel höhere Resonanz als 433,775 mHz. Also der Drahtrwendel ist zu kurz.
Viel Erfolg
Klaus
Moin Klaus,
bei mir scheint es ein Problem mit der Version meines
LiLYGo Moduls T-Beam-V1.1. zu geben. Es gibt unterschiedlich Versionen
jeweils mit AXP192 oder AXP2102 Chip. Ich habe beide Versionen erworben und auch jeweils richtig compiliert.
Keine Funktion. Jetzt versuche herauszubekommen ich ob ich den SX1278 oder SX1268 Loranchip habe, woran
ich das erkenne und dann den Quellcode ändere.
vy73
Ralf
So jetzt bin ich ein Stück weiter.
Ich wusste nicht dass über die Serielle Schnittstelle informationen ausgegeben werden.
Die Software crashed mit einem IntegerDivideByZero ab.
GPS hat hier in der Wohnung keinen Empfang
Dort erhalte folgende Meldungen:
[INFO][PMU] init done!
[INFO][Main] LoRa APRS Tracker by OE5BPA (Peter Buchegger)
[INFO][Main] Version: 23.36.01
[ERROR][Configuration] Failed to read file, using default configuration.
[INFO][LoRa] Set SPI pins!
[INFO][LoRa] Set LoRa pins!
[INFO][LoRa] frequency: 433775000
[INFO][LoRa] LoRa init done!
[INFO][Main] Smart Beacon is: On
[INFO][Main] setup done...
25.09.2023 18:05:28
Sats: 0 HDOP: 99.99
Next Bcn: ~06:28:15
Bat: 4.13V, 0mA
Smart Beacon: On
Guru Meditation Error: Core 1 panic'ed (IntegerDivideByZero). Exception was unhandled.
Core 1 register dump:
PC : 0x400d54ce PS : 0x00060830 A0 : 0x800e2850 A1 : 0x3ffcbb80
A2 : 0xc0bfcbcc A3 : 0x3ffbdb68 A4 : 0x3f403434 A5 : 0x00000000
A6 : 0x3ffc3ca4 A7 : 0x3ffbdb6c A8 : 0x800d54c8 A9 : 0x3ffcbb60
A10 : 0x3ffc3ca4 A11 : 0x00000000 A12 : 0xfffffc02 A13 : 0x000003fe
A14 : 0x7ff00000 A15 : 0x40590000 SAR : 0x0000001d EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000 LBEG : 0x40092599 LEND : 0x400925a9 LCOUNT : 0xffffffff
Backtrace: 0x400d54cb:0x3ffcbb80 0x400e284d:0x3ffcbd40
ELF file SHA256: 5dc06be85ee99d59
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
modeBig GrinIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13232
load:0x40080400,len:3028
entry 0x400805e4
In der Situation ist es wohl das Beste, sich an den Autor zu wenden.
Es gibt inzwischen ja einige forks der Software von OE5BPA mit unterschiedlicher Schwerpunktsetzung.
Benutzer, die gerade dieses Thema anschauen: 1 Gast/Gäste
